Старый 13.03.2016, 03:41   #1
organicax: Current work is frozen message on the warehouse mobile device
Источник: http://organicax.com/2016/03/12/curr...mobile-device/
One of the things about adopting an integrated warehouse solution is that what you control in the backend will control what the workers are able to do on the floor. For example if there is an issue with an order and sales rings the operations team to stop an order then you can put a block on work. This will create a message a message on the mobile device for example current work is frozen. This can be useful to flag that in the system if work has already been communicated to the team on the floor. Then if needed walk down and physically deal with the communication.
Here is a quick look at the message
Cheers
Lachlan
Filed under: Warehouse management
organicax: Setting up the warehouse mobile device portal for a second company Blog bot DAX Blogs 0 09.03.2016 03:28
Kashperuk Ivan: Tutorial: Custom work types and shipment notes on the mobile device in Warehouse management module in Dynamics AX 2012 R3 Blog bot DAX Blogs 0 01.07.2015 19:11
DynamicsAxSCM: Creating Custom Solutions with the Warehouse Mobile Device Portal Blog bot DAX Blogs 0 13.03.2015 16:11
DynamicsAxSCM: Warehouse Mobile Device Portal Architecture Blog bot DAX Blogs 0 03.03.2015 19:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
Часовой пояс GMT +3, время: 21:02.
