Старый 09.03.2016, 10:11   #1
Dynamics AX Sustained Engineering: Announcing support for SQL Server 2012 SP3 with AX 2012 R2 & R3
Источник: https://blogs.technet.microsoft.com/...ax-2012-r2-r3/
Microsoft Dynamics AX 2012 R3 Cumulative Update 10 and AX 2012 R2 Cumulative Update 9 are now compatible with SQL Server 2012 SP3. The Microsoft Dynamics AX 2012 System Requirements have been updated to reflect this change.
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
Dynamics AX Sustained Engineering: Announcing an update to enable the use of SQL Server 2014 with the AX 2012 R2 CU7 version of the Data Import/Export Framework (DIXF) Blog bot DAX Blogs 0 23.03.2015 22:12
Dynamics AX Sustained Engineering: Announcing Support of AX 2012 and AX 2012 R2 on Windows 8.1. and IE11 Blog bot DAX Blogs 0 16.04.2014 02:12
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2012 and SQL Server 2012 SP1 with Dynamics AX 2009 SP1 Blog bot DAX Blogs 3 27.05.2013 14:41
Часовой пояс GMT +3, время: 07:12.
