#1 |
organicax: WMS Allow pick location override
Источник: http://organicax.com/2016/03/03/wms-...tion-override/
============== In a previous post we had a look at the allow put location override parameter. There is a companion parameter to this if you want to allow the use to be able to change the pick location. This can be handy if the physical stock doesn’t match the system suggested location. The system suggested location will come from the location directives. The parameter is called allow pick location override and can be found on the warehouse worker setup. Here is a quick walk through in AX2012 R3 CU9 AX Build 7.0.1265.3015 Cheers Lachlan Filed under: Warehouse management Источник: http://organicax.com/2016/03/03/wms-...tion-override/
