Старый 02.03.2016, 08:12   #1
axmfg: Round up work for raw material picking to match the handling unit
Источник: https://blogs.msdn.microsoft.com/axm...handling-unit/
This blog post describes the functionality of a new hofix that is released in the Microsoft Knowledge base (KB) in article 3120530.  After installing this hotfix it is now possible to configure the location directive for raw material picking, so work can be rounded up to the nearest handling unit in which the material is...
axmfg: Rounding up work for raw material picking to the nearest handling unit Blog bot DAX Blogs 0 20.01.2016 22:13
emeadaxsupport: Checklist of setup and configuration items for getting Input Location from Resource assigned with Put work in Raw material picking with Warehouse Management processing in AX 2012 Blog bot DAX Blogs 0 12.08.2015 20:17
DynamicsAxSCM: How to support a case picking operation using wave containerization in AX2012R3 Blog bot DAX Blogs 0 19.11.2014 16:11
axmfg: Warehouse work for raw material picking split per route operation Blog bot DAX Blogs 0 22.09.2014 18:11
Часовой пояс GMT +3, время: 16:54.
