Старый 02.04.2015, 19:11   #1
emeadaxsupport: AX 2012 for Retail: “The number for one time customer is missing” and payment posts with earlier date than sales invoice when posting Retail Statements
Источник: http://blogs.msdn.com/b/axsupport/ar...tatements.aspx
We have seen a few different issues lately when customers have unmarked “Delivery Date Control” in System administration>Setup>Licensing>License configuration > Trade.
The first issue that can happen is the following error when posting the Retail statement:
” The number for one-time customer is missing.”
The error means that AX cannot find the default customer for the store (not that the customer has the One-time customer box marked).
The first thing to check is that the sysadmin user also receives the error on the one-time customer.
The second issue we see is that when posting a Retail statement the Payment posts with an earlier date than the sales invoice.
The work-around below has resolved both issues in the past.
Set transDate = salesHearder.DeliveryDate instead of transDate = salesHeader.ReceiptDateConfirmed in the RetailStatementSalesOrderCreator/Run class:
If you have the above issues and Delivery Date Control is not unmarked, I would suggest creating a support incident as this would involve further investigation.
Note:
"Microsoft provides programming examples for illustration only, without warranty expressed or implied, including, but not limited to, the implied warranties of merchantability or fitness for a particular purpose. This mail message assumes that you are familiar with the programming language that is being demonstrated and the tools that are used to create and debug procedures."
This has not been officially tested by Microsoft and should be fully tested before implementation.
emeadaxsupport: Documentation collection: Inplace upgrade MS Dynamcis AX 2012 RTM --> AX 2012 R2 CU7 Blog bot DAX Blogs 0 22.06.2014 01:19
emeadaxsupport: AX for Retail 2012 R2: Working with Custom Fields for Receipts Blog bot DAX Blogs 0 16.02.2013 23:12
emeadaxsupport: AX for Retail 2012: Working with Custom Fields Blog bot DAX Blogs 0 07.08.2012 07:12
Часовой пояс GMT +3, время: 18:05.
