Старый 08.09.2014, 11:11   #1
bojensen: Reports in SSRS with Multi Value Parameters and NULL Values
Источник: http://blogs.bojensen.eu/2014/09/08/...d-null-values/
If you are creating a SSRS report in Visual Studio 2008 and would like a parameter to display multiple values including NULL values, you will get a message saying, “A multi-value parameter cannot include null values”.   However, there is a 2 step method to work around this. 1) In the Dataset that provides values…
Read more →
emeadaxsupport: SSRS report tuning possibility in MS Dynamics AX 2012 RTM Blog bot DAX Blogs 0 21.06.2014 19:19
crminthefield: Optimize CRM 2011 Service Channel allocation for multi-threaded processes using .NET Task Parallel Library (TPL) and a thread-local service proxy Blog bot Dynamics CRM: Blogs 0 12.09.2012 00:11
Gareth Tucker: Duplicate Record Button using Jscript in Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 31.07.2012 16:11
javascripterrors: ssrs 2005 multi value parameters allow null values Blog bot Dynamics CRM: Blogs 0 16.09.2011 09:12
mscrm4ever: CRM 4.0 Supported Multi Select (Picklist) Control Blog bot Dynamics CRM: Blogs 0 25.12.2008 15:05
Часовой пояс GMT +3, время: 20:51.
