Старый 07.08.2014, 16:11   #1
palleagermark: Check the SQL statement generated from a regular X++ select statement
Источник: http://www.agermark.com/2014/08/chec...ated-from.html
So here is another small tip based on me reading Inside Microsoft Dynamics AX 2012 R3.
If you want to know what SQL statement the SQL Server query processor generates based on a regular X++ select statement, you can add to the keyord generateOnly to the statement an afterwards call the getSQLStatement method on the record buffer.
Example:
AccountingEvent accountingEvent;
SourceDocumentHeader sourceDocumentHeader;
select generateonly accountingEvent
join sourceDocumentHeader
where sourceDocumentHeader.RecId == accountingEvent.SourceDocumentHeader;
info (accountingEvent.getSQLStatement());
That turns out something like this:
emeadaxsupport: Trace Parser Tip - How to find a SQL statement across all sessions Blog bot DAX Blogs 0 24.12.2013 14:11
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
palleagermark: Create ZIP files from AX Blog bot DAX Blogs 0 28.11.2011 17:11
palleagermark: Spell checking from AX Blog bot DAX Blogs 0 04.04.2008 10:05
Часовой пояс GMT +3, время: 09:04.
