Старый 25.06.2014, 05:22   #1
mscrmblog: Disable Automatic Document Property Promotion on a List
Источник: http://mscrmblog.net/2014/06/25/disa...ion-on-a-list/
So if you’ve come across the problem where users will download a document previously upload which has metadata tags against it, they will rewrite the whole document and upload but the old properties and metadata properties have been set from the last document.
Fortunately its a feature that can be disabled however not through the UI. This can be done either using SharePoint Manager or creating a feature in Visual studio which will update the property on the SPWeb.
The property is:
ParserEnabledMSDN link: http://msdn.microsoft.com/en-us/libr...erenabled.ASPX
You can also read up on Document Property Promotion and Demotion: http://msdn.microsoft.com/en-us/libr...ffice.14).aspx
In a simple feature you can disabled it using the following:
var web = properties.Feature.Parent as SPWeb;web.AllowUnsafeUpdates = true;web.ParserEnabled = false;web.Update();
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
Microsoft Dynamics CRM Team Blog: Marketing with Dynamic List Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
mscrmblog: Customize Marketing List (List Member View) Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 13:59.
