Старый 17.09.2013, 20:11   #1
emeadaxsupport: AX for Retail POS Credit Card Authorization is failing with the error: "The authorization could not be completed, Error code: InvalidExpirationDate"
Источник: http://blogs.msdn.com/b/axsupport/ar...date-quot.aspx
In support, we have seen a few cases where processing credit cards in POS generates the following error, when Payment services is setup correctly:
Error message: Invalid Argument: ExpirationDate
In order to use credit cards in POS, the ‘Check expiration date’ box must be marked in the Card Setup window for the Card Payment method assigned to the store.
This is by design and documented in the following TechNet article:
http://technet.microsoft.com/EN-US/l.../hh597124.aspx
Check expiration date: Select the check box to require that cashiers enter card expiration dates.
Important: Credit cards and debit cards can be processed only if the Check expiration date check box is selected.
In AX, go to Retail>>Common>>Retail channels>>Retail stores and select your store.
Select the ‘Set up’ menu and Set up>>Payment methods.
Select the ‘Cards’ Payment method and click on the Card setup button.
Select the Card ID that is generating the error.
In the General fast tab, under the Setup section, mark the ‘Check expiration date’ checkbox.
When you run the job to push the Payment method change to POS, you should now be able to process the credit card, assuming you have EFT setup properly to process credit cards.
emeadaxsupport: Dynamics AX 2012 for Retail: Items not showing in POS Blog bot DAX Blogs 0 13.09.2012 21:11
Часовой пояс GMT +3, время: 17:15.
