Старый 14.06.2013, 21:11   #1
dynamicscpm: Using non-printing columns in column calculations
Источник: http://blogs.msdn.com/b/dynamicscpm/...culations.aspx
When using non-printing columns in your column calculations be sure to think about the columns you want included in the calculation. If you define range calculation, only the printing columns are included in the calculation. If you define each column individually in the calculation, printing and non-printing columns are included in the calculation.
In the screen shots below, you can see the differences in a range calculation versus individually defining each column in the calculation.
Column definition:
Report results:
dynamicscpm: Adding a column that divides an amount by the number of reporting periods Blog bot DAX Blogs 0 08.06.2013 00:19
emeadaxsupport: AX for Retail: Printing Receipts with Windows Drivers Blog bot DAX Blogs 0 25.01.2012 10:11
axaptapedia: Multi Column Blog bot DAX Blogs 0 05.02.2008 17:25
Часовой пояс GMT +3, время: 09:31.
