Старый 25.07.2012, 21:11   #1
sashanazarov: The X++ debugger does not open...
Источник: http://sashanazarov.blogspot.com/201...-not-open.html
... although you turned off "Execute business operations in CIL" in the "Tools > Options".
Then there is probably a runAs(...) method somewhere down the call stack.
You can find such a runAs-call by setting a breakpoint in Visual Studio, attaching to the process and running your logic again. After the runAs-call is found, you can simply go replace it with a direct static method call.
For example:
After this change, the X++ debugger will stop where needed.
Remember - this change is only for debugging purpose. You should not do that in the production code.
Could not open dll DeflateZlib.dll vvk84 DAX: Администрирование 7 27.03.2012 12:45
Leon's CRM Musings: Why The Customer Is Not Always Right Blog bot Dynamics CRM: Blogs 0 24.09.2011 18:12
gatesasbait: When the debugger is not an option... Blog bot DAX Blogs 0 30.11.2007 01:53
Часовой пояс GMT +3, время: 15:42.
