Старый 26.02.2012, 11:11   #1
emeadaxsupport: AX 2012 Retail POS installation issue
Источник: http://blogs.msdn.com/b/axsupport/ar...ion-issue.aspx
Description:
AX 2012 FeaturePack
Installation of AX 2012 Retail POS on POSReady 2009(Win XP) fails
System Requirements
Reason:
AX 2012 RTM is not supporting the Windows Embedded POSReady 2009 operating system, but AX RETAIL POS supports it.
Workaround:
What you need to do is to execute the MSI directly with these parameters
Msiexec /i directexecute=1
So for POS it would be
Msiexec /i RetailPOS.msi directexecute=1
The RetailPOS.msi is found on the cd under the Msi\RetaiPOS directory
Author: Kim Truelsen
Blog date: 26/2-2012
emeadaxsupport: Installation of Microsoft Dynamics AX 2009 or 2012 client may fail on a Microsoft Windows 7 x64 (64-bit operating system) Blog bot DAX Blogs 0 20.09.2011 23:12
Rahul Sharma: Dynamics AX for Retail POS Development Blog bot DAX Blogs 2 19.09.2011 15:30
emeadaxsupport: How can I slipstream Cumulative Updates for AX 2012 as part of a new installation Blog bot DAX Blogs 0 22.08.2011 23:11
Часовой пояс GMT +3, время: 05:42.
