Старый 31.07.2008, 22:05   #1
gatesasbait: Code code to generate code in Dynamics AX
Источник: http://gatesasbait.spaces.live.com/B...B9F5!240.entry
Good morning,
The following job will create a new static method on the SalesLine table at runtime. Use it as a tutorial for TreeNodes' AOTadd(), AOTsetSource(), AOTcompile() and AOTfindChild() methods.
Note that access to such code should be restricted through security keys, namely the 'SysDevelopment' key since this code definitely uses a dangerous API.
public static void createMethodTest(Args _args)
 #AOT
 #define.myNewStaticMethod('myNewStaticMethod')
 #define.methods('methods')
  parentNode;
  methodNode;
 MemberFunction subMethodNode;
  sysDictTable = new SysDictTable(tablenum(SalesLine));
 Source  = "public static void myNewStaticMethod()\n"
 + "{\n"
 + "    ;\n"
 + "    info(\"test\");\n"
 + "}\n";
 if (hasSecuritykeyAccess(
 securitykeynum(SysDevelopment), AccessType::Delete))
 parentNode = TreeNode::findNode(#TablesPath+'\\'+sysDictTable.name());
  if (parentNode)
 methodNode = parentNode.AOTfindChild(#methods);
  subMethodNode = methodNode.AOTfindChild(#myNewStaticMethod);
 if (!subMethodNode)
 subMethodNode = methodNode.AOTadd(#myNewStaticMethod);
 subMethodNode.AOTsetSource(source, true); //true sets 'static'
  parentNode.AOTcompile();
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 16:50.
