#15 |
А вот код хранимки
Отформатирован тут https://sqlformat.org/ X++: CREATE PROCEDURE [dbo].[CREATEUSERSESSIONS] @clientType int, @sessionType int, @serverid int, @versionid int, @userid nvarchar(8), @lanExt nvarchar(10), @manExt nvarchar(10), @computerName nvarchar(80), @sid nvarchar(124), @recid bigint, @startId int, @maxusers int, @licenseType int, @masterId int, @maxClientId int, @dataPartition nvarchar(8), @sessionid int OUTPUT, @loginDateTime datetime OUTPUT AS DECLARE @return_val AS int DECLARE @first AS int DECLARE @max_val AS int DECLARE @counter AS int BEGIN SELECT @sessionid = -1 SELECT @max_val = -1 SELECT @counter = 0 SELECT @loginDateTime = dateadd(ms, -datepart(ms, getutcdate()), getutcdate()) if(NOT exists (SELECT * FROM SYSSERVERSESSIONS WITH (NOLOCK) WHERE SERVERID = @serverid AND Status = 1)) BEGIN SELECT @sessionid = -2 RETURN END SELECT @first = min(SESSIONID) FROM SYSCLIENTSESSIONS WITH (UPDLOCK, READPAST) WHERE STATUS = 0 AND SESSIONID > @maxClientId AND SESSIONID <> @masterId IF (SELECT count(*) FROM SYSCLIENTSESSIONS WHERE SESSIONID IN (@first)) > 0 BEGIN IF (@licenseType = 0) BEGIN UPDATE SYSCLIENTSESSIONS SET STATUS = 1, VERSION = @versionid, SERVERID = @serverid, USERID = @userid, LOGINDATETIME = @loginDateTime, SID = @sid, USERLANGUAGE = @lanExt, HELPLANGUAGE = @manExt, CLIENTTYPE = @clientType, SESSIONTYPE = @sessionType, CLIENTCOMPUTER = @computerName, DATAPARTITION = @dataPartition WHERE SESSIONID IN (@first) END ELSE IF (@licenseType = 1) BEGIN UPDATE SYSCLIENTSESSIONS SET STATUS = 1, VERSION = @versionid, SERVERID = @serverid, USERID = @userid, LOGINDATETIME = @loginDateTime, SID = @sid, USERLANGUAGE = @lanExt, HELPLANGUAGE = @manExt, CLIENTTYPE = @clientType, SESSIONTYPE = @sessionType, CLIENTCOMPUTER = @computerName, DATAPARTITION = @dataPartition WHERE SESSIONID IN (@first) AND ( (SELECT count(SESSIONID) FROM SYSCLIENTSESSIONS WHERE CLIENTTYPE = @clientType AND ((STATUS = 1) OR (STATUS = 2))) < @maxusers) END ELSE IF (@licenseType = 2) BEGIN UPDATE SYSCLIENTSESSIONS SET STATUS = 1, VERSION = @versionid, SERVERID = @serverid, USERID = @userid, LOGINDATETIME = @loginDateTime, SID = @sid, USERLANGUAGE = @lanExt, HELPLANGUAGE = @manExt, CLIENTTYPE = @clientType, SESSIONTYPE = @sessionType, CLIENTCOMPUTER = @computerName, DATAPARTITION = @dataPartition WHERE SESSIONID IN (@first) AND ( (SELECT count(SESSIONID) FROM SYSCLIENTSESSIONS WHERE CLIENTTYPE = @clientType AND (USERID = @userid) AND ((STATUS = 1) OR (STATUS = 2))) > 0 OR (SELECT count(DISTINCT USERID) FROM SYSCLIENTSESSIONS WHERE CLIENTTYPE = @clientType AND ((STATUS = 1) OR (STATUS = 2))) < @maxusers) END IF @@ROWCOUNT = 0 SELECT @sessionid = 0 ELSE SELECT @sessionid = @first END ELSE BEGIN IF (@licenseType = 1) BEGIN IF (SELECT count(SESSIONID) FROM SYSCLIENTSESSIONS WHERE CLIENTTYPE = @clientType AND ((STATUS = 1) OR (STATUS = 2))) >= @maxusers SELECT @sessionid = 0 END ELSE IF (@licenseType = 2) BEGIN IF (( (SELECT count(DISTINCT USERID) FROM SYSCLIENTSESSIONS WHERE CLIENTTYPE = @clientType AND ((STATUS = 1) OR (STATUS = 2))) >= @maxusers) AND ( (SELECT count(SESSIONID) FROM SYSCLIENTSESSIONS WHERE CLIENTTYPE = @clientType AND (USERID = @userid) AND ((STATUS = 1) OR (STATUS = 2))) = 0)) SELECT @sessionid = 0 END IF (@sessionid = -1) OR (@licenseType = 0) BEGIN WHILE (@sessionid = -1 AND @counter < 5) BEGIN SET @counter = @counter + 1 IF (SELECT count(SESSIONID) FROM SYSCLIENTSESSIONS WITH (UPDLOCK) WHERE STATUS = 0 OR STATUS = 1 OR STATUS = 2 OR STATUS = 3) = 0 SELECT @max_val = @startId ELSE SELECT @max_val = max(SESSIONID)+1 FROM SYSCLIENTSESSIONS WITH (UPDLOCK) IF (@max_val > 65535) SELECT @sessionid = -3 ELSE BEGIN INSERT INTO SYSCLIENTSESSIONS(SESSIONID, SERVERID, VERSION, LOGINDATETIME, USERID, SID, USERLANGUAGE, HELPLANGUAGE, CLIENTTYPE, SESSIONTYPE, RECID, CLIENTCOMPUTER, STATUS, DATAPARTITION) VALUES(@max_val, @serverid, @versionid, @loginDateTime, @userid, @sid, @lanExt, @manExt, @clientType, @sessionType, @recid, @computerName, 1, @dataPartition) IF @@ROWCOUNT = 0 BEGIN SELECT @sessionid = -1 END ELSE SELECT @sessionid = @max_val END END END END END |
| За это сообщение автора поблагодарили: Lankey (1). | |
| Теги |
| ax2009 |
