Старый 17.06.2022, 19:16   #4
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,343 / 3563 (125) ++++++++++
Злой Вы. В России давать ссылку на community.dynamics.com без комментария.
Вытащу статью, правда без картинок и ссылок (картинки не грузятся, ссылки не работают)
A few months ago I wrote a post on how to convert Excel documents to PDF with X++. Well, that piece of code made it into production! image But I just notice it does not necessarily compile with Ax Build.
The error:
The xlApp declaration does not compile because Excel is not installed on the server and AX build can only be completed on the server. If you compile this same piece of code in the AOT on a server that has Excel installed, it compiles without a problem.
My solution(s):
Install Excel on the server. I am not sure if this will allow AX Build to compile the code, but at least you can then open the AOT after AX build on the sever and compile like I described here.
Since I could not install Excel on the server, I did the following:
  1. Compile with AX Build on the server.
  2. If you have a compile error related to Microsoft.Office.Interop.Excel, start the server and open the AOT on a terminal server that has Excel installed.
  3. Compile the code with normal F7 compile.
  4. Compile the CIL on the terminal server.
Hope that helps! Let me know in the comments if you know of a better way to solve this.
DAX09: где найти библиотеку References\Microsoft.Office.Interop.Excel oleggy DAX: Программирование 6 24.05.2021 12:29
Microsoft.Office.Interop.Excel DmitryS DAX: Программирование 20 25.04.2014 12:24
emeadaxsupport: Microsoft Dynamics AX 2012 Office Addins tab does not appear in Microsoft Excel 2007 or Word 2007 on a 64bit Windows system Blog bot DAX Blogs 0 25.02.2012 05:42
Sample Design Patterns: Microsoft Dynamics AX - Remedy for slow Microsoft Excel import Blog bot DAX Blogs 0 29.05.2011 17:13
Часовой пояс GMT +3, время: 02:25.
