powerobjects: Authentication to Dynamics 365 using Azure Function v3 (.NET core)
Источник: https://powerobjects.com/dynamics-36...n-v3-net-core/
============== There are not many examples of trying to use Azure Function v3 (.NET core) to access Dynamics 365. If you find yourself trying to convert the Azure Function v1 (.NET Framework) to v3 (.NET core), you will be better off creating a new Azure Function. And if you’re trying to access Dataverse using the same libraries to access Dataverse in v3 (.NET core) that you were using in v1 (.NET Framework)... Source Источник: https://powerobjects.com/dynamics-36...n-v3-net-core/
