Старый 20.02.2019, 12:11   #1
kurthatlevik: Near real-time replenishment in Dynamics 365 F&O
Источник: https://kurthatlevik.com/2019/02/20/...namics-365-fo/
There is a lot of good stuff on the horizon for Dynamics 365. I highly recommend that you check out the following article of some new planning services that will come in the April 2019 release.
https://docs.microsoft.com/en-gb/bus...anning-service
To make this happen, I would expect the planning to go deeper into the SQL stack, and also to maximize the utilization of in-memory processing of the transactions.
For Retailers, this will be highly appreciated, where limited space in the stores means that shelf replenishment several times each day is common. Especially for perishable products with limited shelf-time. Keeping things fresh and presentable is a necessity for the customer to buy. The ability to more quickly react to customer demands ensures that the customers actually find the products in your store. And the same aspect, when there are a slower sale, the ability to adjust down the replenishment according to activity. This saves cost and increases profit. In Retail, it is the small improvements that in sum creates the big results.
For the planning service to work, it needs the transactions to take action on. In Dynamics 365 for Retail we must choose between the ability to aggregate the transactions coming from the POS/Channel databases, or more quickly posting the statements. I’m looking forward to many good discussions on this area.
The future is faster
За это сообщение автора поблагодарили: gl00mie (2).
Старый 21.02.2019, 00:49   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Судя по описанию, интересная штука, только смущает одно: такое ощущение, что это будет пачка хранимок на стеройдах, работающая где-то сбоку на зеркале рабочей базы в качестве источника данных. Т.е. кастомизируемость этого - под большим вопросом. А если так, то я слабо верю, что тем же ритейлерам это все из коробки подойдет. Да, вендор знает про неснижаемый остаток и min/max/кратность поставки (еще со сводника в Аксапте 3.0). Да, вендор знает, что склад магазина обычно мал, но знает ли он про ассортиментную матрицу и те пропорции между категориями товара, которые ритейлер старается выдерживать при пополнении склада магазина? Знает ли, что у товара (скажем, обувной коробки) есть объем, причем у разного товара - разный (зимняя обувь в среднем объемнее летней), и пополнение может учитывать его, рассчитывая количество к поставке под объём склада магазина? А без таких нюансов это всё на реальных проектах, как мне кажется, не взлетит.
Но в целом новость позитивная: вендор всеми силами старается загрузить побольше своих облачных мощностей и находит им интересные применения.
Старый 21.02.2019, 01:33   #3
ax_mct is offline
ax_mct
Banned
2,548 / 1091 (0) ++++++++
Не фанат Retai решенияl, но за хранимые процедуры. Мне кажется что сложность расширения и поддержки хранимых процедур - это миф.
P.S. Хотя если в данном случае это набор DLL (что скорее всего) которые вызывают хранимые процедуры то конечно какие там кастомизации.
Последний раз редактировалось ax_mct; 21.02.2019 в 01:44.
Старый 21.02.2019, 10:10   #4
gl00mie is offline
gl00mie
Я лично ничего не имею против хранимок, но их нет как класса в процессе разработки для D365FO. А в контексте обсуждаемой новости подозреваю, что там доступа к разработке не будет вовсе.
Старый 21.02.2019, 14:44   #5
ax_mct is offline
ax_mct
Banned
Кстати, да. Согласен. Не подумал что база она на недоступной орбите.
Ну вот, и не пофлеймить
survivingcrm: Demystifying Dynamics 365 & Power Platform Licensing: Part 1 Blog bot Dynamics CRM: Blogs 0 01.02.2019 01:22
kurthatlevik: First Aid Kit for Dynamics 365 for Retail; A messy blog post Blog bot DAX Blogs 0 10.05.2018 17:11
Часовой пояс GMT +3, время: 19:22.
