Art Of Creation: Workflow: An unexpected error has occurred while opening the workflow. See the event log on the AOS and contact your system administrator to resolve the issue.
Источник: http://www.artofcreation.be/2015/08/...lve-the-issue/
============== When trying to view or edit a workflow, the following error can pop up: An unexpected error has occurred while opening the workflow. See the event log on the AOS and contact your system administrator to resolve the issue.This is a general error and it could mean a lot of things. Make sure you check the obvious things first:
In my case, none of this helped. Because this was a CLR exception, I modified the try/catch in the method that was throwing the error to show the inner exception. The method Forms\WorkflowEditorHost.run was modified so it looked like this: <div class="codecolorer-container xpp default" style="overflow:auto;white-space:nowrap;border:1px solid #9F9F9F;width:435px;"><div class="xpp codecolorer" style="padding:5px;font:normal 12px/1.4em Monaco, Lucida Console, monospace;white-space:nowrap">public void run() { System.Exception interopException; try { modelEditorControl.Load(workflowConfiguration, userSettings); <span style="color: #007f00;">//
Тема | Ответов | |||
Workflow протокол ошибор (Event alert) | 5 | |||
axinthefield: Dynamics AX Event IDs | 0 |
