Старый 24.07.2017, 16:06   #10
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
Записей в блоге: 1
Устанавливаем SSRS. Вроде все успешно завершается. Лезем в AX - нет ничего. Смотрим в лог установки - и оба-на, оказывается ошибка. WTF? С ошибкой-то разобрались, но писать "Setup was completed successfully", когда на самом деле "Reporting Services Extension was not configured" как-то странно.
2017-07-20 20:16:42Z Error executing command: USE [*******];
2017-07-20 20:16:42Z DECLARE @tableName NVARCHAR(64);
2017-07-20 20:16:42Z DECLARE @tableId int;
2017-07-20 20:16:42Z DECLARE @utilElementTypeTable AS INT;
2017-07-20 20:16:42Z SELECT @tableName = N'SRSServers';
2017-07-20 20:16:42Z SELECT @utilElementTypeTable = 44;
2017-07-20 20:16:42Z SELECT @tableId = [AxId] FROM [ModelElement] WHERE [ElementType] = @utilElementTypeTable AND [Name] = @tableName;
2017-07-20 20:16:42Z SELECT @tableId;
2017-07-20 20:16:42Z Invalid object name 'ModelElement'.
2017-07-20 20:16:42Z Error executing command: use [*******]; exec [sp_AddReportServer] @serverId = N'*******', @serverUrl = N'*******', @isDefault = 1, @axReportFolder = N'DynamicsAX', @description = N'', @reportManagerUrl = N'*******', @sqlServerInstanceName = N'MSSQLSERVER', @aosServerName = N'*******', @configurationId = N'*******', @isSharepointIntegrated = 0, @recId = 5637268379
2017-07-20 20:16:42Z Cannot insert the value NULL into column 'AOSID', table '*******.dbo.SRSSERVERS'; column does not allow nulls. INSERT fails.
2017-07-20 20:16:42Z Changed database context to '*******'.
2017-07-20 20:16:42Z The statement has been terminated.
2017-07-20 20:16:42Z ******************************************************************************************************
2017-07-20 20:16:42Z Reporting Services Extension was not configured. An unknown issue occurred. Please contact your administrator.
Изображения
axapta, cil, d365fo, guid, rasset, uuid, uuidv7, баг
Часовой пояс GMT +3, время: 10:54.
