MS Dynamics 365 for Operations Update 5 VM Download (облачная версия)
С яммера (нужен доступ на connect):
Виртуалка с Update 5 Announcement:Technical Preview for Upcoming Dynamics 365 for Operations "Spring 2017" release is available Environment access: Enter the following preview code in Lifecycle Services Preview Feature Management: 3a002c6b-2900-4051-b981-17b6ab322f0c Select Cloud Hosted Environments within a Lifecycle Services Project to deploy a Demo environment to Azure. You will see the new topology option: Dynamics 365 for Operations - Demo (Technical Preview). NOTE: at this time only Cloud hosted environments are available Documentation: Available as a Download via the following Connect Invitation ID: https://connect.microsoft.com/site13...=AX7-2P72-VYPF Feedback: Available through Connect Invitation ID: https://connect.microsoft.com/site13...=AX7-2P72-VYPF Выложил здесь - чтобы не потерять ссылку потом
Возможно сделать все. Вопрос времени Последний раз редактировалось sukhanchik; 06.04.2017 в 20:37. |
| Теги |
| d365o, hotfix |
