Сообщение от Blog bot
First off, it's coupling the base class too tightly with the sub-classes, which it should not be aware of at all.
Secondly, because the application model where the base class is declared might be sealed (e.g, foundation models are already sealed), you would not be able to add additional cases to the switch block, basically locking the application up for any extension scenarios. зачем такие усложнения как описано? или есть еще какие-то дополнительные моменты Последний раз редактировалось trud; 19.03.2017 в 12:32. |
