Вернуться   AXForum > Прочие обсуждения > forum.mazzy.ru > Полезные ссылки
Старый 20.07.2005, 08:37   #3
lastelf is offline
lastelf
А еще можно использовать скрипт, который желательно повесить в задания SQL. Скрипт лучше выполнить два раза, т.к. на первый раз не всегда отрабатывает
SET NOCOUNT ON
DECLARE @LogicalFileName sysname,
@MaxMinutes INT,
@NewSize INT
-- *** MAKE SURE TO CHANGE THE NEXT 3 LINES WITH YOUR CRITERIA. ***
USE AXDB30 --This is the name of the database for which the log will be shrunk.
SELECT @LogicalFileName = 'AXDB30_log' , -- Use sp_helpfile to identify the logical file name that you want to shrink.
@MaxMinutes = 1, -- Limit on time allowed to wrap log.
@NewSize = 2000 -- in MB
-- Setup / initialize
DECLARE @OriginalSize int
SELECT @OriginalSize = size -- in 8K pages
FROM sysfiles
WHERE name = @LogicalFileName
SELECT 'Original Size of ' + db_name() + ' LOG is ' +
CONVERT(VARCHAR(30),@OriginalSize) + ' 8K pages or ' +
CONVERT(VARCHAR(30),(@OriginalSize*8/1024)) + 'MB'
FROM sysfiles
CREATE TABLE DummyTrans
(DummyColumn char (8000) not null)
-- Wrap log and truncate it.
DECLARE @Counter INT,
@StartTime DATETIME,
@TruncLog VARCHAR(255)
SELECT @StartTime = GETDATE(),
@TruncLog = 'BACKUP LOG ' + db_name() + ' WITH TRUNCATE_ONLY'
-- Try an initial shrink.
DBCC SHRINKFILE (@LogicalFileName, @NewSize)
EXEC (@TruncLog) -- backup log with truncate_only
-- Wrap the log if necessary.
WHILE @MaxMinutes > DATEDIFF (mi, @StartTime, GETDATE()) -- time has not expired
AND @OriginalSize = (SELECT size FROM sysfiles WHERE name = @LogicalFileName) -- the log has not shrunk
AND (@OriginalSize * 8 /1024) > @NewSize -- The value passed in for new size is smaller than the current size.
BEGIN -- Outer loop.
SELECT @Counter = 0
WHILE ((@Counter < @OriginalSize / 16) AND (@Counter < 1000))
BEGIN -- update
INSERT DummyTrans VALUES ('Fill Log') -- Because it is a char field it inserts 8000 bytes.
DELETE DummyTrans
SELECT @Counter = @Counter + 1
END -- update
EXEC (@TruncLog) -- See if a trunc of the log shrinks it.
END -- outer loop
SELECT 'Final Size of ' + db_name() + ' LOG is ' +
CONVERT(VARCHAR(30),size) + ' 8K pages or ' +
CONVERT(VARCHAR(30),(size*8/1024)) + 'MB'
FROM sysfiles
DROP TABLE DummyTrans
PRINT '*** Perform a full database backup ***'
SET NOCOUNT OFF
Часовой пояс GMT +3, время: 18:54.
