#6 |
My understanding of Green is that the suite of applications will be based on a global code base, with the middleware layer the Microsoft Business Framework, which builds on top of .Net Framework. Is that correct, and how does the current set of business applications fit into Green?
What you described Green as is correct. Подробнее... http://www.eweek.com/article2/0,1759,1500107,00.asp |
