Шаман форума
Документация и ссылки на утилиты расчета конфигурации серверов на technet (форум требует регистрации, регистрация доступна всем желающим):
*** К сожалению technet закрт ***
All information in this post is strictly confidential. If you have read it in error, please forget it immediately. |
Microsoft Dynamics AX 4.0 white paper: Benchmarking on Hewlett-Packard Proliant Servers
Benchmark Data Composition The benchmark was run on a 177 GB base database. The system was configured as follows:
All scenarios were run using the same hardware configuration of 8 homogeneous AOS servers communicating with a single instance Microsoft SQL Server™ 2005 database: AOS Server Specification Model HP DL385 Processor 2 x 2.6 gigahertz (GHz) AMD64 Memory 4 GB ECC HardDisk (BootDrive) 2 x 72 gigabyte (GB) 15K RPM Raid1 HardDisk (PageFile) 1 x 36 GB 15K RPM Network HP NC7782 Gigabit Ethernet AOS Software Settings 3 GB Switch 32-bit version of Microsoft Windows Server® 2003 with Service Pack SP1 (SP1), Enterprise Edition Single AOS instance per server Visual Studio Team System Client Specification Model HP DL145 Processor 2 x 1.8 GHz AMD64 Memory 2 GB ECC HardDisk Maxtor 40 GB IDE Network Broadcom NetXtream Gigabit Ethernet Visual Studio Team System Software Settings 32-bit version of Windows Server 2003 with SP1, Standard Edition Database Server Specification Model HP DL585 Processor 4 x 2.6 GHz AMD64 Memory 16 GB ECC HardDisk (BootDrive) 2 x 72 GB 15K RPM Raid1 HardDisk (PageFile) 1 x 36 GB 15K RPM Network Broadcom NetXtream Gigabit Ethernet 6 Database Software Settings 3 GB Switch 64-bit version of Windows Server°2003 with SP1, Enterprise Edition 32-bit version of Microsoft SQL Server 2005 with Service Pack 1 (SP1) |
Последние требования для AX4.0
http://www.microsoft.com/dynamics/ax/produ...quirements.mspx |
