Там все немного запущено, изначально стандарт не предназначен для такой задачи (по крайней мере по книге продаж, но думаю аналогичная проблема и с покупками), на одном из проектов обращались в MS по данной проблеме, я не знаю чем дело закончилось.
Для начала нужно исправить вот тут BookDataCalc_RU\unpack : X++: public boolean unpack(container packedClass) { //boolean ret; boolean ret = true; //SN Integer version = conPeek(packedClass,1); SalesPurchBookRecId_RU bookRecIdNew; switch (version) { case #CurrentVersion: bookRecIdNew = this.parmBookRecId(); [version, #CurrentList] = packedClass; if (bookRecIdNew) { this.parmBookRecId(bookRecIdNew); closeBook = NoYes::No; } this.initBookTable(); break; default: ret = false; } return ret; } X++: System.InvalidCastException: Unable to cast object of type 'Dynamics.Ax.Application.SalesBookTable_RU' to type 'Dynamics.Ax.Application.SalesPurchBookTable_RU'. at Dynamics.Ax.Application.SalesPurchBookTable_RU.Gettodate() in SalesPurchBookTable_RU.getToDate.xpp:line 24 at Dynamics.Ax.Application.SalesBookTable_RU.Gettodate() in SalesBookTable_RU.getToDate.xpp:line 9 at Dynamics.Ax.Application.BookAmountsEngine_RU.Initqueryrun() in BookAmountsEngine_RU.initQueryRun.xpp:line 12 at Dynamics.Ax.Application.BookAmountsEngine_RU.Fetchtaxmap() in BookAmountsEngine_RU.fetchTaxMap.xpp:line 63 at Dynamics.Ax.Application.BookDataCalc_Sales_RU.End() in BookDataCalc_Sales_RU.end.xpp:line 41 at Dynamics.Ax.Application.BookDataCalc_RU.Run() in BookDataCalc_RU.run.xpp:line 34 at Dynamics.Ax.Application.BookDataCalc_Sales_Export_RU.Run() in BookDataCalc_Sales_Export_RU.run.xpp:line 7 at Dynamics.Ax.Application.BatchRun.runJobStaticCode(Int64 batchId) in BatchRun.runJobStaticCode.xpp:line 54 at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 13 at BatchRun::runJobStatic(Object[] ) at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters) at BatchIL.taskThreadEntry(Object threadArg)
Sergey Nefedov |
| За это сообщение автора поблагодарили: ice321i (1). | |
