Старый 11.08.2015, 09:41   #4
axm2013
Гость
n/a
Я бы попробовал
https://community.dynamics.com/ax/f/33/t/96805
"his kind of error are previal in Ax 2012 SSRS also. When the returned record set has different meta data the adapter fails to recognize it . The best thing to do Delete report from Report Manager. Remove entries of the report in SysLastValues. IF using Ax2012 delete records in SRSReportQuery table also.
Restart AOS ans Reproting service and redeploy and execute"
emeadaxsupport: Error viewing an SSRS Report from Microsoft Dynamics AX 2009 - Sys.WebForms.PageRequestManagerServerErrorException: An unknown error occured while processing the request on the server Blog bot DAX Blogs 0 22.03.2012 02:13
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table. Blog bot DAX Blogs 0 02.12.2011 00:13
daxdilip: Object Server 01: Internal Error occured executing stored procedure when creating session for the AOS Blog bot DAX Blogs 0 29.09.2010 18:05
Часовой пояс GMT +3, время: 10:38.
