Breakpoint; in CIL code
Источник: http://alexvoy.blogspot.com/2015/01/...-cil-code.html
============== I needed to debug batch processing in BatchRun.ServerGetTask() method. ![]() It was a wrong idea to add breakpoint; instruction into a managed code. Of course, after stopping my AOS did not start anymore because of the error: Just-In-Time debugging this exception failed with the following error: The operation attempted is not supported The easiest way to recover this problem is to delete the forementioned instruction and recompile CIL, but I have not access to AOT X++ editor anymore. Alternatevily, as described in How-To-Debug-Managed-Code-In-AX2012, I did catch this breakpoint in Visual Studio during the short period between Starting and Stopped statutes of AOS service. Launch Visual Studio as administrator. ![]() Open the class method in question directly frpm xppCIL\Source folder. ![]() ![]() Start the AOS service. ![]() Switch back to Visual Studio and attach to the process. It appeared in a few seconds. ![]() Then it stopped at the problematic breakpoint. ![]() Pressing F5 each time it stopped there (actually every minute, as it supposed to be for batch processing), I changed my code back and run full CIL. ![]() Please, do not place breakpoint; in managed code like I did. Источник: http://alexvoy.blogspot.com/2015/01/...-cil-code.html
