Старый 27.04.2013, 00:24   #30
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,343 / 3563 (125) ++++++++++
А можно ли ее держать на другом SQL-сервере? Как указать имя/путь?
Нельзя. По кр мере с т.з. тренингов.
This change will require that the business data AND the metadata databases reside on the
same instance of SQL. The reason this is required is to ensure that join queries which span
tables in both metadata and business databases [some security scenarios use this] can be
handled seamlessly. SQL server allows querying of another database on the same server
instance even when the connection is to a different database
И еще:
Now, in Microsoft Dynamics AX 2012 R2, the process will be the same conceptually, but the
toolset used will now be the use of the SQL Management console functionality of using a
database backup of the metadata database (export of the modelstore using AXUtil) and the
database restore of the metadata database (import of the modelstore using AXUtil) to move
the metadata to a different environment. This would be similar to copying the AOD files in
Microsoft Dynamics AX 2009 or prior between different application folders to move
metadata.
Последний раз редактировалось sukhanchik; 27.04.2013 в 00:26.
За это сообщение автора поблагодарили: mazzy (5).
ax2012, документация, как правильно, скачать (download)
Microsoft Dynamics AX 2012 White Paper: Microsoft Project Server 2010 Integration Vadik DAX: База знаний и проекты 1 31.07.2011 18:43
Sample Design Patterns: Upgrade to Microsoft Dynamics AX 2009 and issues with the global address book Blog bot DAX Blogs 0 21.12.2010 11:11
dynamics-ax: Interview with Microsoft's Lachlan Cash about Dynamics AX Technical Conference Blog bot DAX Blogs 0 28.09.2010 01:05
AX UK: Microsoft Dynamics AX 3.0 to 2009 Data and Code Upgrade Training Blog bot DAX Blogs 1 03.02.2009 11:15
AX UK: Two New AX Upgrade White Papers Available on PartnerSource Blog bot DAX Blogs 0 07.11.2006 10:32
Часовой пояс GMT +3, время: 21:12.
