Старый 06.11.2012, 08:11   #1
Malaysia: Copying a record
Источник: http://axmas.blogspot.com/2012/11/copying-record.html
class MainAccountCopy
static void main(Args _args)
MainAccount mainAccount1;
MainAccount mainAccount2;
mainAccount1 = MainAccount::findByMainAccountId('211100');
ttsBegin;
mainAccount2.data(mainAccount1);
mainAccount2.MainAccountId = '211101';
if (!mainAccount2.validateWrite())
throw Exception::Error;
mainAccount2.insert();
ttsCommit;
Gareth Tucker: Duplicate Record Button using Jscript in Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 31.07.2012 16:11
Microsoft Dynamics CRM Team Blog: How to Add a Record Wall to a Form Blog bot Dynamics CRM: Blogs 0 10.11.2011 04:19
dynamics-ax-dev: Retrieving Record Values in an Enterprise Portal Wizard/Tunnel Blog bot DAX Blogs 0 02.11.2010 18:05
emeadaxsupport: Error when trying to register the AIF services - "Cannot create a record in Data Policy Schema Information (AifDocumentField)" Blog bot DAX Blogs 0 29.03.2010 21:05
palleagermark: Saving the reference to a unique record as a string Blog bot DAX Blogs 0 20.10.2008 11:05
Часовой пояс GMT +3, время: 18:56.
