emeadaxsupport: Accessing .NET global namespace from X++
Источник: http://blogs.msdn.com/b/axsupport/ar...ce-from-x.aspx
============== In case you need access a global namespace (object without namespace) like following definition, you could use a this X++ code. C# code: namespace KFEnumNamepace { public enum KFEnumNamespaced { ValueNA = 100, ValueNB, ValueNC, ValueND } } public enum KFEnumGlobal { ValueA = 1000, ValueB, ValueC, ValueD } X++ Code: (enumdll is name of assembly which contain Enums) static void JobEnumDLL(Args _args) { ClrObject co; System.Type typeOfEnvironment; System.Type typeOfEnum; System.Reflection.Assembly assem; ; co = KFEnumNamepace.KFEnumNamespaced::ValueNC; print co; assem = System.Reflection.Assembly::Load("enumdll"); typeOfEnum = assem.GetType("KFEnumGlobal"); co = System.Enum::Parse(typeOfEnum, 'ValueB' ); print co; pause; } --author: Karel Fischl Источник: http://blogs.msdn.com/b/axsupport/ar...ce-from-x.aspx
