Старый 22.02.2012, 20:27   #1
Favor82 is offline
Favor82
Блин при установке отчетности половина наших репортов сбилась и не запускается.. точнее они есть, запускаются но такое ощущение что к датосорсу не конектятся. Ругается на Report Server
An internal error occurred on the report server. See the error log for more details. (rsInternalError) Get Online Help
For more information about this error navigate to the report server on the local server machine, or enable remote errors
А полный лог от репорт сервера выглядит так, что ногу сломишь.
--- End of inner exception stack trace ---
w3wp!library!8!02/22/2012-18:13:14:: i INFO: Exception dumped to: C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\LogFiles flags= ReferencedMemory, AllThreads, SendToWatson
w3wp!library!b!02/22/2012-18:14:19:: Call to GetSystemPermissionsAction().
w3wp!library!b!02/22/2012-18:14:22:: Call to ListChildrenAction(/, False).
w3wp!library!f!02/22/2012-18:14:24:: Call to ListChildrenAction(/BTR, False).
w3wp!library!b!02/22/2012-18:14:25:: Call to ListChildrenAction(/BTR/Pearaamat, False).
w3wp!library!8!02/22/2012-18:14:27:: Call to GetPermissionsAction(/BTR/Pearaamat/Kasumiaruanne).
w3wp!library!f!02/22/2012-18:14:27:: Call to GetPermissionsAction(/BTR/Pearaamat/Kasumiaruanne).
w3wp!library!13!02/22/2012-18:14:27:: Call to GetPermissionsAction(/BTR/Pearaamat).
w3wp!library!13!02/22/2012-18:14:27:: Call to GetPermissionsAction(/BTR/Pearaamat/Kasumiaruanne).
w3wp!library!8!02/22/2012-18:14:27:: Call to GetPropertiesAction(/BTR/Pearaamat/Kasumiaruanne, PathBased).
w3wp!library!8!02/22/2012-18:14:28:: Call to GetPermissionsAction(/BTR/Pearaamat/Käibeandmik).
w3wp!library!13!02/22/2012-18:14:28:: Call to GetPermissionsAction(/BTR/Pearaamat/Käibeandmik).
w3wp!library!13!02/22/2012-18:14:28:: Call to GetPermissionsAction(/BTR/Pearaamat).
w3wp!library!8!02/22/2012-18:14:28:: Call to GetPropertiesAction(/BTR/Pearaamat/Käibeandmik, PathBased).
w3wp!library!8!02/22/2012-18:14:48:: e ERROR: Throwing Microsoft.ReportingServices.Diagnostics.Utilities.InternalCatalogException: Произошла внутренняя ошибка на сервере отчетов. Дополнительные подробности см. в журнале ошибок., ;
Info: Microsoft.ReportingServices.Diagnostics.Utilities.InternalCatalogException: Произошла внутренняя ошибка на сервере отчетов. Дополнительные подробности см. в журнале ошибок. ---> System.Web.HttpException: The URL-encoded form data is not valid. ---> System.InvalidOperationException: Operation is not valid due to the current state of the object.
at System.Web.HttpValueCollection.ThrowIfMaxHttpCollectionKeysExceeded()
at System.Web.HttpValueCollection.FillFromEncodedBytes(Byte[] bytes, Encoding encoding)
at System.Web.HttpRequest.FillInFormCollection()
at System.Web.HttpRequest.get_Form()
at Microsoft.ReportingServices.WebServer.Global.get_RequestParameters()
at Microsoft.ReportingServices.WebServer.Global.IsViewerRequested()
at Microsoft.ReportingServices.WebServer.Global.IsViewerNeeded()
at Microsoft.ReportingServices.WebServer.Global.DispatchRequest()
at Microsoft.ReportingServices.WebServer.Global.Application_AuthenticateRequest(Object sender, EventArgs e)
Как можно еще проверить в чем же дело, ведь некоторые отчетики работают.. а некоторые нет, пытаются что то загрузить и ошибка выше. Датасорсе проставляю но он как то нереагирует на него.
Как сильно модифицировано ваше приложение Аксапты? mazzy DAX: Прочие вопросы 30 14.04.2011 17:26
Вставка строк в таблицы Аксапты сторонними средствами Андре DAX: База знаний и проекты 1 07.05.2009 16:49
Программный запуск Аксапты из Аксапты DreamCreator DAX: Программирование 11 04.05.2009 10:05
Поле "Стандартная себестоимость" AlexeyBP DAX: Функционал 24 03.08.2006 11:09
изменение вида учета материалов (средняя- стандартная) tolstjak DAX: Функционал 1 31.03.2005 15:58
Часовой пояс GMT +3, время: 04:00.
