Старый 02.11.2010, 20:05   #1
gustafwesterlund: Importing organizations with custom reports
Источник: http://gustafwesterlund.blogspot.com...th-custom.html
The import organization tool is very useful for setting up test or development environements with full production level data. However, I ran into a problem importing today, when importing the organization, I got the following fatal error:
System.InvalidOperationException: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
After a bit of googling I found that this had been discussed in the CRM forums: http://social.microsoft.com/Forums/e...2-759071a82358
Since I imported the organization, mainly to work with duplicates processing, I just removed all custom reports from the CRM database manually and the import went just fine.
Gustaf Westerlund
CEO, Chief Architect and co-Founder at CRM-konsulterna AB
www.crmkonsulterna.se
gustafwesterlund: Publishing reports for external use Blog bot Dynamics CRM: Blogs 0 14.10.2010 17:05
Muhammad Ali Khan: Relating/Connecting MS CRM 4.0 Data With Custom External Content Type Data In SharePoint 2010 Blog bot Dynamics CRM: Blogs 0 04.02.2010 13:05
Microsoft Dynamics CRM Team Blog: Use Shared Data Source for custom Microsoft Dynamics CRM reports Blog bot Dynamics CRM: Blogs 0 05.12.2008 00:05
Microsoft CRM: Exporting Custom Reports to Excel mazzy Dynamics CRM: Функционал 0 12.03.2005 14:36
Часовой пояс GMT +3, время: 15:56.
