Старый 01.12.2009, 15:28   #4
Skyway is offline
Skyway
У меня получился следующий SOAP - запрос:
// Prepare variables for updating a contact.
var tripid = crmForm.ObjectId;
var scode = 1;
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Update xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<entity xsi:type='new_business_trip'>"+
"<statecode>"+scode+"</statecode>"+
"<new_business_tripid>"+tripid+"</new_business_tripid>"+
"</entity>"+
"</Update>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Update");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
alert(msg);
// Display a confirmation message and open the updated contact.
else
alert("Contact with id = "+tripid+" successfully updated.");
В результате запрос вроде как выполняется, но статус командировки не меняется
CRM Programmer: Parse XML date in CRM date with Javascript Blog bot Dynamics CRM: Blogs 0 02.11.2009 17:05
crmdude: Using JavaScript to assign a record Blog bot Dynamics CRM: Blogs 0 09.10.2009 03:17
Все о Microsoft Dynamics CRM: Вспомогательные классы для работы с веб-службами MS CRM 4.0 из JavaScript Blog bot Dynamics CRM: Blogs 0 21.07.2009 14:05
Странности бизнес-процесса на изменение атрибутов записи SLK Dynamics CRM: Функционал 6 19.05.2009 08:14
Событие "Назначение записи" для бизнес-процесса Lazarus Dynamics CRM: Функционал 1 22.01.2009 19:54
Часовой пояс GMT +3, время: 14:42.
