Старый 29.05.2008, 16:01   #15
Bakai Madybaev is offline
Bakai Madybaev
вот мой скрипт, который работает
var ownerLookupItem = new Array;
ownerLookupItem = crmForm.all.ownerid.DataValue;
var lookupData = new Array();
var bUnitLookupItem= new Object();
if (ownerLookupItem != null)
if (ownerLookupItem[0] != null)
var oXmlHttp = new ActiveXObject("Msxml2.XMLHTTP");
var serverurl = "http://inftb:5555/";
sGUID=ownerLookupItem[0].id;
if (sGUID != null)
var sEntityName="systemuser";
var sAttributeName="businessunitid";
var bUID ="";
crmForm.all.new_debug.DataValue = sEntityName + " | " + sGUID + " | "+ sAttributeName;
bUID = GetAttributeValue(sEntityName, sGUID, sAttributeName);
var bUEntityName ="businessunit";
var bUEntityType ="name";
crmForm.all.new_debug.DataValue +=bUEntityName + " | " + bUID + " | "+ bUEntityType;
var bUName = GetAttributeValue(bUEntityName, bUID, bUEntityType);
bUnitLookupItem.id = bUID;
bUnitLookupItem.typename = bUEntityName;
bUnitLookupItem.name = bUName;
lookupData[0] = bUnitLookupItem;
crmForm.all.new_businessunit_phonecall.DataValue = lookupData;
crmForm.all.new_debug.DataValue += " >>" + lookupData[0].id + " | "+ lookupData[0].name;
else
//alert("crmForm.all.ownerid is Null");
function GetAttributeValue(sEntityName, sGUID, sAttributeName)
var xml = "";
xml +="<?xml version=\"1.0\" encoding=\"utf-8\"?>";
xml +="<soap:Envelope xmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\">";
//xml += GenerateAuthenticationHeader();
xml +="<soap:Body>";
xml +="<entityName xmlns=\"http://schemas.microsoft.com/crm/2006/WebServices\">" + sEntityName + "</entityName>";
xml +="<id xmlns=\"http://schemas.microsoft.com/crm/2006/WebServices\">" + sGUID + "</id>";
xml +="<columnSet xmlns=\"http://schemas.microsoft.com/crm/2006/WebServices\" xmlns:q=\"http://schemas.microsoft.com/crm/2006/Query\" xsi:type=\"q:ColumnSet\">";
xml +="<q:Attributes>";
xml +="<q:Attribute>" + sAttributeName + "</q:Attribute>";
xml +="</q:Attributes>";
xml +="</columnSet>";
xml +="</soap:Body>";
xml +="</soap:Envelope>";
var xmlHttpRequest = new ActiveXObject("Msxml2.XMLHTTP");
xmlHttpRequest.Open("POST", serverurl + "/mscrmservices/2006/CrmService.asmx", false);
xmlHttpRequest.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2006/WebServices/Retrieve");
xmlHttpRequest.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xmlHttpRequest.setRequestHeader("Content-Length", xml.length);
xmlHttpRequest.send(xml);
crmForm.all.new_debug.DataValue +=xml;
var doc = xmlHttpRequest.responseXML;
crmForm.all.new_debug.DataValue +=xmlHttpRequest.responseText;
var retValue = "";
if (doc.selectSingleNode("//RetrieveResult/q1:" + sAttributeName) != null)
retValue = doc.selectSingleNode("//RetrieveResult/q1:" + sAttributeName).text;
else
crmForm.all.new_debug.DataValue += xmlHttpRequest.responseXML;
return retValue;
попробуйте разобраться в моем скрипте (это почти то же самое, что и у вас)
Последний раз редактировалось Bakai Madybaev; 29.05.2008 в 16:04.
За это сообщение автора поблагодарили: MFCшный Wizard (1).
Как получить значение поля одной сущности при обработке формы другой сущности zhenek Dynamics CRM: Разработка 25 05.07.2011 16:19
Присвоение одного атрибута сущности значения другого атрибута связанной сущности vital.mih Dynamics CRM: Функционал 38 08.09.2010 10:53
Как создать экземпляр кастомной сущности через SOAP? Tony Green Dynamics CRM: Разработка 7 27.02.2009 08:37
Создание объекта сущности из другого объекта! SnSS Dynamics CRM: Разработка 5 29.05.2008 13:38
Каким образом самопальный лукап привязывается к сущности? tatra Dynamics CRM: Разработка 4 25.09.2007 12:58
Часовой пояс GMT +3, время: 03:30.
