https://community.dynamics.com/ax/f/...34=2#responses
Deploying Managed Web Content Error
Unanswered Hi Matt, I know it is a long time ago, but it might be still relevant to you or to others visiting this topic. I ran into the same issue as you did just yet and then I recalled an another issue I had when I installed Enterprise Portal. In the end this was solved by renaming the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\15.0 registry key into HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\15.0_xx Hope this might help you or others. то дальше аксапта пытается работать только с ней, н находит нужных вещей и падает в ошибку. В общем, в моем случае деплой портала починился. |
Теги |
deploy, issue, sharepoint, sharepoint 2010 |
