Старый 22.11.2018, 21:31   #7
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
перебирай все колонки и ищи с нужным именем. примерно вот так:
// returns the batch caption form control if any in the dialog
private FormStringControl getBatchCaptionControl(DialogRunbase _dialog)
    FormStringControl                  batchCaptionControl;
    // recursive routine to look for the right form control of BatchCaption EDT
    Object findBatchCaptionControl(Object _parentObject)
        int         i;
        Object      childControl;
        Object      foundControl;
        for (i = 1; i <= _parentObject.controlCount(); i++)
            childControl = _parentObject.controlNum( i );
            // this is our boy
            if( childControl is FormStringControl && childControl.extendedDataType() ==  extendedTypeNum(BatchCaption))
                // time to get up
                return childControl;
            else
                if (childControl is FormGroupControl)
                    foundControl = findBatchCaptionControl(childControl);
                    if (foundControl)
                        return foundControl;
        // just step back to check others
        return null;
/////// main routine  /////////////////////////////////////////////////////////////
    if( _dialog && _dialog.batchDialogTabPage())
        batchCaptionControl = findBatchCaptionControl(_dialog.batchDialogTabPage().control());
    return batchCaptionControl;
Felix nihil admirari
За это сообщение автора поблагодарили: yuriy_64 (1).
grid, колонки, переименовать
d365technext: Card Pattern in Grid D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 11:11
atinkerersnotebook: Self Service Reporting For Users – Part 2: Use Edit in Grid as your Reporting Worksheet Blog bot DAX Blogs 0 06.10.2015 15:11
tlefor: Dynamics AX 2012: How Wide is my Grid Column? Blog bot DAX Blogs 0 28.10.2013 10:11
axaptapedia: Filter-by-Grid Blog bot DAX Blogs 2 30.05.2012 13:39
Dynamics AX: DAX 4.0 Filter by Grid [Update] Blog bot DAX Blogs 0 27.04.2007 17:10
Часовой пояс GMT +3, время: 07:13.
