Старый 21.02.2018, 23:34   #15
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
не вижу там " через foreign key relations". вижу только A relation should be defined on the table that is holding the foreign key to the relating table.
ну, и разумеется, Ванин камент про селфи!
Felix nihil admirari
erconsult: Copy-paste automation in D365 FO with a keyboard emulator Blog bot DAX Blogs 5 10.01.2018 13:42
alirazazaidi: Custom financial Dimension shows in lookup D365 for Finance and operations Blog bot DAX Blogs 0 14.09.2017 13:11
organicax: Setting up the Statistical Demand Forecasting in D365 with Azure Machine Learning Blog bot DAX Blogs 0 12.08.2017 01:17
organicax: D365 applying application hotfix Blog bot DAX Blogs 0 11.04.2017 01:31
emeadaxsupport: D365 for Operation CSS Global support incident closure procedure for support incidents involving a bug Blog bot DAX Blogs 0 04.04.2017 22:11
Часовой пояс GMT +3, время: 06:41.
