А еще можно использовать скрипт, который желательно повесить в задания SQL. Скрипт лучше выполнить два раза, т.к. на первый раз не всегда отрабатывает
SET NOCOUNT ON DECLARE @LogicalFileName sysname, @MaxMinutes INT, @NewSize INT -- *** MAKE SURE TO CHANGE THE NEXT 3 LINES WITH YOUR CRITERIA. *** USE AXDB30 --This is the name of the database for which the log will be shrunk. SELECT @LogicalFileName = 'AXDB30_log' , -- Use sp_helpfile to identify the logical file name that you want to shrink. @MaxMinutes = 1, -- Limit on time allowed to wrap log. @NewSize = 2000 -- in MB -- Setup / initialize DECLARE @OriginalSize int SELECT @OriginalSize = size -- in 8K pages FROM sysfiles WHERE name = @LogicalFileName SELECT 'Original Size of ' + db_name() + ' LOG is ' + CONVERT(VARCHAR(30),@OriginalSize) + ' 8K pages or ' + CONVERT(VARCHAR(30),(@OriginalSize*8/1024)) + 'MB' FROM sysfiles WHERE name = @LogicalFileName CREATE TABLE DummyTrans (DummyColumn char (8000) not null) -- Wrap log and truncate it. DECLARE @Counter INT, @StartTime DATETIME, @TruncLog VARCHAR(255) SELECT @StartTime = GETDATE(), @TruncLog = 'BACKUP LOG ' + db_name() + ' WITH TRUNCATE_ONLY' -- Try an initial shrink. DBCC SHRINKFILE (@LogicalFileName, @NewSize) EXEC (@TruncLog) -- backup log with truncate_only -- Wrap the log if necessary. WHILE @MaxMinutes > DATEDIFF (mi, @StartTime, GETDATE()) -- time has not expired AND @OriginalSize = (SELECT size FROM sysfiles WHERE name = @LogicalFileName) -- the log has not shrunk AND (@OriginalSize * 8 /1024) > @NewSize -- The value passed in for new size is smaller than the current size. BEGIN -- Outer loop. SELECT @Counter = 0 WHILE ((@Counter < @OriginalSize / 16) AND (@Counter < 1000)) BEGIN -- update INSERT DummyTrans VALUES ('Fill Log') -- Because it is a char field it inserts 8000 bytes. DELETE DummyTrans SELECT @Counter = @Counter + 1 END -- update EXEC (@TruncLog) -- See if a trunc of the log shrinks it. END -- outer loop SELECT 'Final Size of ' + db_name() + ' LOG is ' + CONVERT(VARCHAR(30),size) + ' 8K pages or ' + CONVERT(VARCHAR(30),(size*8/1024)) + 'MB' FROM sysfiles WHERE name = @LogicalFileName DROP TABLE DummyTrans PRINT '*** Perform a full database backup ***' SET NOCOUNT OFF |
