Старый 19.05.2011, 11:36   #20
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Сообщение от KKNDSTER Посмотреть сообщение
Уже задолбался прямо....
Использую вот этот:
function GetAttributeValueFromID(sEntityName, GUID, sAttributeName)
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "";
xml = xml+"<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<entityName>"+sEntityName+"</entityName>"+
"<id>"+GUID+"</id>"+
"<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+
"<q1:Attributes>"+
"<q1:Attribute>"+sAttributeName+"</q1:Attribute>"+
"</q1:Attributes>"+
"</columnSet>"+
"</Retrieve>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/200...vices/Retrieve");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
var result = resultXml.selectSingleNode("//q1:" + sAttributeName).nodeTypedValue;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
result = " ";
alert(msg);
// Display the retrieved value.
else
return result;
crmForm.new_serialnumber.DataValue = GetAttributeValueByEntityId("new_nomenclaturalposition", "document.crmForm.all.new_nomenclaturashippinglin.DataValue[0].id", "new_warranty");
Пишет, что значение функции
Приветствую, (спасибо)
Всё равно пишет что значение функции типа не определены, или Null или не является объектом Function....
Чуточку внимательности в написании кода и всё будет ок. Красным выделил ошибку - надеюсь поймёте в чём дело. А то получается, что я решаю проблему, за решение которой вам платят, а мне - нет.
Как получить значение поля одной сущности при обработке формы другой сущности zhenek Dynamics CRM: Разработка 25 05.07.2011 16:19
Присвоение одного атрибута сущности значения другого атрибута связанной сущности vital.mih Dynamics CRM: Функционал 38 08.09.2010 10:53
Тип грида (GridType) при выводе списка связанной сущности alsherin Dynamics CRM: Разработка 4 07.07.2009 19:18
Как вытащить данные из лукапа на 2 сущности? vital.mih Dynamics CRM: Функционал 1 06.07.2009 16:07
Как создать экземпляр кастомной сущности через SOAP? Tony Green Dynamics CRM: Разработка 7 27.02.2009 08:37
Часовой пояс GMT +3, время: 17:43.
