У меня получился следующий SOAP - запрос:
// Prepare variables for updating a contact. var tripid = crmForm.ObjectId; var scode = 1; var authenticationHeader = GenerateAuthenticationHeader(); // Prepare the SOAP message. var xml = "<?xml version='1.0' encoding='utf-8'?>"+ "<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+ " xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+ " xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+ authenticationHeader+ "<soap:Body>"+ "<Update xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+ "<entity xsi:type='new_business_trip'>"+ "<statecode>"+scode+"</statecode>"+ "<new_business_tripid>"+tripid+"</new_business_tripid>"+ "</entity>"+ "</Update>"+ "</soap:Body>"+ "</soap:Envelope>"; // Prepare the xmlHttpObject and send the request. var xHReq = new ActiveXObject("Msxml2.XMLHTTP"); xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false); xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Update"); xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8"); xHReq.setRequestHeader("Content-Length", xml.length); xHReq.send(xml); // Capture the result var resultXml = xHReq.responseXML; // Check for errors. var errorCount = resultXml.selectNodes('//error').length; if (errorCount != 0) { var msg = resultXml.selectSingleNode('//description').nodeTypedValue; alert(msg); } // Display a confirmation message and open the updated contact. else { alert("Contact with id = "+tripid+" successfully updated."); } В результате запрос вроде как выполняется, но статус командировки не меняется |
