#21 |
Так... Первый параграф с небольшими стилистическим изменениями... Прошу рассматривать, как мое предложение, не более того
![]() What's It All About? I have been talking to consultants and developers who works with DAX and I know that the issues regarding inventory closing and stock cost calculation have become one of the severest for the majority of implementation projects. Users treat the inventory closing as a ‘black box’ delivering various results every time it's run depending on the phase of Moon. In my opinion, this is caused by the lack of information, which is dispersed across the whole documentation. Furthermore, some tricks of this procedure are not documented at all and need to be discovered with the cut-and-try method or by studying the source code of inventory closing. In this article I'll try to explain in detail how this procedure works and to guide you through some other issues related to the cost calculation. A part of the information has been collected from different documents about DAX; another part captures my own experience gathered while working with Axapta 3.0 and reverse-engineering its source code. I haven’t verified everything in the version 4.0 but - according to my analysis of the source code – the algorithm hasn’t been changed significantly. This document is addressed to experienced DAX (formerly Axapta) consultants and software architects who have questions on the subject. The reader should understand basic ideas of the Trade and Logistics module and should have already tried to run the inventory closing.
Not registered yet? Register here! Have comments, questions, suggestions or anything else regarding our web site? Don't hesitate, send them to me |
#22 |
Зачем организовывать?
http://erpkb.com/ Русский вариант с любезного разрешения автора планирую выложить сюда http://erpkb.com/Axapta/sebestoimost Английский можно сюда http://erpkb.com/Axapta/Cost Или на http://www.axaptapedia.com/ |
#23 |
#24 |
Упс... Согласен. Промахнулся.
Предлагаю редактировать статью дальше здесь: http://erpkb.com/Axapta/Cost Первоначальный вариант я уже туда забросил.
#25 |
Перевод - это, конечно, здорово, но объясните мне вот что:
1 числа закупили 1 штуку номенклатуры по цене 200 рублей (зак1)
20 числа закупили еще 4 штуки - по цене 250 рублей (зак2) Потом – задним числом провели 5ым числом перенос 2 штук со склада 1 на склад 2. (пер1) Потом - задним числом перенесли 6ым числом эти две штуки обратно (пер2) 25 числа – все продали (зкз1) Ну и наконец – 27ым числом доначислили 20 рублей накладных расходов на первую закупку. Цитата:
До закрытия склада имеем следующую картину себестоимостей и количеств в проводках:
Код: Документ Дата Количество Себестоимость Склад Зак1 01.01.2007 1 270 1 Пер1 05.01.2007 -2 -480 1 Пер1 05.01.2007 2 480 2 Пер2 06.01.2007 -2 -480 2 Пер2 06.01.2007 2 480 1 Зак2 20.01.2007 4 1000 1 Зкз1 25.01.2007 -5 -1200 1
#26 |
to gl00mie:Значит у меня ошибка там
Я вообще этот пример пересчитывал поздно вечером и меня этот процесс изрядно достал Постараюсь подправить чуть позже.
#27 |
Banned
#28 |
я думаю, на аксаптапедию английский вариант адекватнее
#29 |
Это почему же?
Статью написанную русским человеком, переведенную русскими людьми и на Аксаптапедию. Даже обидно стало. Конечно, если автор не против, то можно и туда. Но давайте лучше буржуев к нам на русские ресурсы тащить. |
#30 |
#31 |
1. Предлагаю перевести аксаптапедию в категорию "Русские ресурсы"
2. Наверное, не очень хорошо иметь английский текст с русским оформлением странички. PS. Вообще, сейчас получается что аксофрум это наиболее богатый по контенту ресурс по аксапте (ИМХО затыкает за пояс ньюсгруппы ms). И если бы кто-нибудь был "интеллектуальным челноком" переводящим информацию по Аксапте на английский, то он мог бы сделать на этом себе имя или популярность какому-нибудь сайту |
#32 |
Шаман форума
Сообщение от belugin
2. Наверное, не очень хорошо иметь английский текст с русским оформлением странички. PS. Вообще, сейчас получается что аксофрум это наиболее богатый по контенту ресурс по аксапте (ИМХО затыкает за пояс ньюсгруппы ms). И если бы кто-нибудь был "интеллектуальным челноком" переводящим информацию по Аксапте на английский, то он мог бы сделать на этом себе имя или популярность какому-нибудь сайту Другими словами - переводить имеет смысл erpkb или ей подобные базы знаний. 2 mazzy - оффтопик не мой :-)
All information in this post is strictly confidential. If you have read it in error, please forget it immediately. |
#33 |
Banned
Переведены еще три главы:
"Traversing inventory movements" (я) "Why inventory goes negative?", "Instant cost price" (автор) Прошу общественность отредактировать труд. Он лежит, как обычно, на http://erpkb.com/Axapta/Cost |
#34 |
Banned
Хотел бы еще раз encourage знатоков английского языка отредактировать две последние главы. Поскольку самому мне лень.
#35 |
В заголовке темы ссылка поломалась
Теперь правильная видимо эта : http://blogs.technet.com/denisfed/ar...23/705202.aspx по крайней мере Яндекс так считает. |
#36 |
После прочтения статьи, появился вопрос. В разделе "Как мониторить процесс закрытия склада?"
написано , что если нашли ситуацию отрицательного остатка то их нужно примаркировать. Так вот, как делается эта маркировка вручную, где находится данный функционал? |
| За это сообщение автора поблагодарили: S.Kuskov (0). | |
#37 |
MCT
вопрос больше к книге Руководство пользователя по AX2009, однако решил запостить в эту тему....
Исходные данные: 1. В примере везде фигурирует один и тот же товар 2. Используется складская аналитика «Номер партии» (первичная, физические запасы, финансовые запасы). 3. Есть приходный лот (лот 1), по которому есть три приходные проводки с одним номером партии. a. 1шт – 100рСреднемгновенная себестоимость 4. Продаю 1шт (лот 2) a. Маркирую. На форме маркировки вижу одну строку. По факту маркировки - в двух проводках (приходной и расходной) проставляется ссылка на лот. В моем примере маркирован оказался приход со стоимостью 100р.Именно такое поведение системы меня заинтересовало, т.к. в Руководстве пользователя по DAX2009 том 1 страница 1121 написано: «Если текущей номенклатуре присвоен номер партии или серийный номер, включенный в финансовые запасы, то маркировка игнорируется и выполняется калькуляция себестоимости». По написанному я понимаю, что себестоимость должна быть рассчитана без учета маркировки и должна составить: (100+200+400)/3 =233,34р Но ведь маркировка отработала в моем примере. Себестоимость расхода была взята на основании макированной приходной проводки... Таким образом вопрос: перекрывает ли все-таки номер партии или серийный номер маркировку в момент расчете среднемгновенной себестоимости расхода? Закрытие склада 5. При закрытие склада себестоимость расхода пересчитывается также с учетом маркировки. В моем примере - мой расход сопоставлен с маркированные приходом, принцип сопоставления = Маркировка. В Руководстве пользователя по DAX2009 том 1 страница 1122 написано: «При закрытии и корректировке запасов расходы и приходы номенклатур сопоставляются согласно маркировке, если выполнены следующие условия. 1. Номера партий или серийные номера, включенные в финансовые запасы, не используются.» У меня использован номер партии (стоит флаг «финансовые запасы»), но закрытие все равно отработало с учетом маркировки. Таким образом вопрос: перекрывает ли все-таки номер партии или серийный номер маркировку при закрытии склада? Последний раз редактировалось d&m; 29.03.2010 в 13:11. |
#38 |
В общем - маркировка игнорируется при закрытии склада если приходная и расходная проводки имеют разные значения аналитики финансового склада. То есть - если партия является аналитикой финансового склада и ты пытаешься примаркировать приход и расход с разными аналитиками - маркировка будет проигнорирована при закрытии. Если номер партии одинаковый - то себестоимость будет считаться с учетом маркировки.
#39 |
MCT
Сообщение от fed
Но ведь книга как раз этому противоречит - или не верно трактую написанное? В Руководстве пользователя по DAX2009 том 1 страница 1122 написано: «При закрытии и корректировке запасов расходы и приходы номенклатур сопоставляются согласно маркировке, если выполнены следующие условия. 1. Номера партий или серийные номера, включенные в финансовые запасы, не используются.» У меня использован номер партии (стоит флаг «финансовые запасы»), но закрытие все равно отработало с учетом маркировки. |
#40 |
Как же на практике создать такую ситуацию ? Полухакерскими методами (редактирование кодов аналитики в проводке, редактирование настроек складских аналитик) ? |
| Теги |
| faq, закрытие склада, полезное, себестоимость |
