Старый 06.04.2017, 20:33   #1
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,342 / 3563 (125) ++++++++++
MS Dynamics 365 for Operations Update 5 VM Download (облачная версия)
С яммера (нужен доступ на connect):
Виртуалка с Update 5
Announcement:Technical Preview for Upcoming Dynamics 365 for Operations "Spring 2017" release is available
Environment access:
Enter the following preview code in Lifecycle Services Preview Feature Management: 3a002c6b-2900-4051-b981-17b6ab322f0c
Select Cloud Hosted Environments within a Lifecycle Services Project to deploy a Demo environment to Azure. You will see the new topology option: Dynamics 365 for Operations - Demo (Technical Preview).
NOTE: at this time only Cloud hosted environments are available
Documentation:
Available as a Download via the following Connect Invitation ID: https://connect.microsoft.com/site13...=AX7-2P72-VYPF
Feedback:
Available through Connect Invitation ID: https://connect.microsoft.com/site13...=AX7-2P72-VYPF
Выложил здесь - чтобы не потерять ссылку потом
Последний раз редактировалось sukhanchik; 06.04.2017 в 20:37.
d365o, hotfix
Dynamics AX Update 1 VM with SQL 2016 RTM download error MikeR DAX: Администрирование 8 02.11.2016 09:37
jaestevan: Microsoft Dynamics 365 for Operations Blog bot DAX Blogs 0 02.11.2016 01:11
Часовой пояс GMT +3, время: 00:09.
