Старый 21.03.2012, 14:11   #1
emeadaxsupport: Accessing .NET global namespace from X++
Источник: http://blogs.msdn.com/b/axsupport/ar...ce-from-x.aspx
In case you need access a global namespace (object without namespace) like following definition, you could use a this X++ code.
C# code:
namespace KFEnumNamepace
public enum KFEnumNamespaced
        ValueNA = 100,
        ValueNB,
        ValueNC,
        ValueND
public enum KFEnumGlobal
    ValueA = 1000,
    ValueB,
    ValueC,
    ValueD
​X++ Code: (enumdll is name of assembly which contain Enums)
static void JobEnumDLL(Args _args)
    ClrObject co;
    System.Type typeOfEnvironment;
    System.Type typeOfEnum;
    System.Reflection.Assembly assem;
    co = KFEnumNamepace.KFEnumNamespaced::ValueNC;
    print co;
    assem = System.Reflection.Assembly::Load("enumdll");
    typeOfEnum = assem.GetType("KFEnumGlobal");
    co = System.Enum::Parse(typeOfEnum, 'ValueB' );
    print co;
    pause;
--author: Karel Fischl
ssmantha: Debugging .NET code called from X++ code in AX 2012 Blog bot DAX Blogs 1 11.11.2011 15:50
emeadaxsupport: When browsing AX 2009 Role Centers, you get an error: An unexpected error has occurred on systems with .NET Framework v4.0 installed Blog bot DAX Blogs 1 28.07.2010 08:24
emeadaxsupport: Possibilities to create Memory Dumps from crashing processes Blog bot DAX Blogs 0 12.05.2010 19:05
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Microsoft Dynamics CRM Team Blog: Accessing a SQL Database from a Microsoft Dynamics CRM Plug-in Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 20:58.
