Старый 08.07.2011, 18:11   #1
:) axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010
Источник: http://axforum.info/forums/blog.php?b=264
Ну чтож, захотелось подружить Dynamics Ax 2009 c SharePoint Foundation 2010 и началось...
:) Установленный SharePoint Foundation 2010 аксапта не видит, и жаждет SharePoint Services 3.0 Sp1
Далее читаем внимательно (информация в них дублируется, ставить КВ 2278963):
  1. Dynamics AX 2009 и Sharepoint 2010 http://blogs.msdn.com/b/aeremenk/arc.../10050859.aspx
  2. Compatibility Result for Microsoft SharePoint 2010 - August 2010 http://blogs.technet.com/b/dynamicsa...gust-2010.aspx
  3. И конечно Microsoft Dynamics AX 2009 System Requirements http://www.microsoft.com/en-us/dynam...ents-2009.aspx
Microsoft SharePoint 2010 is supported with Microsoft Dynamics AX 2009 Service Pack 1. If you plan to use SharePoint 2010, you must download and install the hotfix package available with Microsoft Knowledge Base article number 2278963. For more information about installing and deploying Enterprise Portal on SharePoint 2010, see the related post on the Microsoft Dynamics AX Sustained Engineering blog.
А что там такого в KB 2278963 (~ 75Мб)? :) :
  • Application\
  • Kernel\
  • Setup Assemblies\
  • Deployment of Microsoft SharePoint 2010 with Microsoft Dynamics AX 2009 SP1.docx
3. Clean Installation
The following set of instructions iterates the installation steps for a clean installation of Enterprise Portal – Microsoft SharePoint 2010 on Microsoft Dynamics AX 2009 SP1.
Assumptions:
• Windows Server 2008 with Microsoft Dynamics AX 2009 SP1 without Enterprise Portal Role Center deployed.
• Install Microsoft SharePoint 2010
• Create a new site in Microsoft SharePoint 2010 to ensure that Microsoft SharePoint 2010 is installed successfully.
Выкрутасы с чистой установкой KB 2278963, все описано в Deployment of Microsoft SharePoint 2010 with Microsoft Dynamics AX 2009 SP1.docx
• Step 1: Update setup
To update the Setup application, follow these steps:
1. Copy the contents of the CD folder from the Microsoft Dynamics AX 2009 DVD to a shared network folder.
Because all later Microsoft Dynamics AX installations must be performed from this folder, make sure that all users who will install Microsoft Dynamics AX 2009 can access this folder.
2. Copy the Microsoft.Dynamics.Framework.Deployment.Portal.dll and Microsoft.Dynamics.Framework.Portal.dll files from the Setup directory of this hotfix package and paste them into the following locations by replacing the existing files:
• [SharedFolder]\CD\Msi\Components32\Program Files\Microsoft Dynamics AX\50\Client\Bin
• [SharedFolder]\CD\Msi\Components64\Program Files (x86)\Microsoft Dynamics AX\50\Client\Bin
3. Copy the Microsoft.Dynamics.Framework.Deployment.Portal.dll to:
• [SharedFolder]\CD\Msi\Components64\Program Files\Microsoft Dynamics AX\50\Setup
• [SharedFolder]\CD\Msi\Components32\Program Files\Microsoft Dynamics AX\50\Setup
4. Copy the AxSetup.exe file from the Setup Assemblies directory of this hotfix package and paste the file into the following location by replacing the existing files:
• [SharedFolder]\CD\Support
• Step 2: Install Binary Patch
1. On any machine that has the Microsoft Dynamics AX 2009 client and AOS installed, run the AxUpdate.exe file from the Kernel directory of the hotfix package, and then follow the instructions that are provided by the Installation wizard.
NOTE: Application of this binary patch, will update files that are already installed:
• AxUpdatePortal.exe
• Microsoft.Dynamics.Framework.Deployment.Portal.dll
• Microsoft.Dynamics.Framework.Portal.dll
• Step 3: Install Application Patch
1. On any machine that has the Microsoft Dynamics AX 2009 client installed, run the AxUpdate.exe file from the Application directory of the hotfix package, and then follow the instructions that are provided by the Installation wizard.
o Application of this application patch will update the following AOT nodes
• SysEPDeployment
• AxWebParts.cab
• Step 4 : Deploy Enterprise Portal Role Center by running Setup.exe from the CD folder
Перед установкой Application Patch предлагается проверить через Impact Analysis feature for Dynamics AX 2009 (Средство анализа влияния) KB974255, как повлияет kb2278963.xpo на приложение.
Учтите, что KB974255 "Это обновление применимо к версии Microsoft Dynamics AX 5.0.1000.52-5.0.1500.2093 файлов приложения." ;) Время я только потратил, у меня Rollup 7.
О ужас, KB 2278963 работает с "Это обновление применимо к версии 5.0.1000.52-5.0.1500.3560 файлов приложения."
Т.е. 5.0.1500.3761 = 2009 SP1 Hotfix Rollup 6 (RU6), Rollup 7 = 5.0.1500.4570
Встрял на:
=== Запуск стадии выполнения ===
Запуск исполняемого файла клиента Microsoft Dynamics AX: C:\Program Files\Microsoft Dynamics AX\50\Client\bin\ax32.exe "-regconfig=Dev" "-logdir=C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2011-07-08 16-56-12" "-startupcmd=autorun_C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2011-07-08 16-56-12\GetVersionInformation.xml"
Это обновление неприменимо к данной установке Microsoft Dynamics AX, поскольку установлены файлы приложения другой версии. Это обновление применимо к версии 5.0.1000.52-5.0.1500.3560 файлов приложения.
Программе установки не удалось завершить установку.
Это обновление неприменимо к данной установке Microsoft Dynamics AX.
Курю мануал: AX 2009 Technical Journal: AX 2009 Rollup 6 and KB 2278963 (SharePoint 2010) и emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963
Продолжение следует ....
Связанная информация по KB2278963 из Knowledgebase:
P.S. +
Последний раз редактировалось Poleax; 11.07.2011 в 11:17. Причина: оформление
ax2009, enterprise portal, role center, sharepoint
Rahul Sharma: MS SharePoint 2010 with Dynamics AX 2009 SP1 Enterprise Portal Blog bot DAX Blogs 0 12.10.2010 15:05
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Часовой пояс GMT +3, время: 03:30.
