Старый 01.03.2010, 15:55   #3
LOGIC_BBS is offline
LOGIC_BBS
IHMO Вам нужнен новый релиз
Release Notes Data Director 2.26.7
1 Introduction
This is a maintenance release of the 2.26 DD. See chapter 4 for details on bugs fixed and
improvements.
1.1 Supported Operating Environments
The following operating systems are supported:
- MS Windows XP Professional, 32 bit
- MS Windows 2003 Server, 32 bit
- MS Vista, 32 bit
1.2 Supported Databases
The following databases are fully supported:
· MS Dynamics NAV (5.01, 6.00)
· MS SQL Server 2005
· MS SQL Express
· MS Dynamics AX 4.0 .Net Business Connector (does not support writing of BLOBs)
· MS Dynamics AX 2009 .Net Business Connector (does not support writing of BLOBs)
The following databases are supported but are not tested:
· MS Dynamics NAV (1.30, 2.01, 2.50, 2.60, 2.65, 3.01, 3.10, 3.60, 3.70, 4.00, 4.01, 4.02, 4.03, 5.00)
Note: The 5.00 version of the CFront has a known bug where it does not release
database connections properly and accumulates temp files causing it to
eventually hang. Use version 5.01 of the CFront instead.
· MS SQL Server 2000 and 2008
· MS Dynamics AX 3.0 Com Connector (does not support writing of BLOBs)
1.3 Supported Backend Systems
The following backend systems are fully supported:
· LS Retail NAV 5.01
· LS Retail NAV 5.05
· LS Retail NAV 6.0
· LS Retail AX 4.10
· LS Retail AX 2009
The following backend systems are supported but are not tested:
· LS Retail NAV 4.00
· LS Retail NAV 4.10
· LS Retail NAV 4.20
· LS Retail NAV 5.00
· LS Retail AX 3.60
