Блин при установке отчетности половина наших репортов сбилась и не запускается.. точнее они есть, запускаются но такое ощущение что к датосорсу не конектятся. Ругается на Report Server
An internal error occurred on the report server. See the error log for more details. (rsInternalError) Get Online Help
For more information about this error navigate to the report server on the local server machine, or enable remote errors
А полный лог от репорт сервера выглядит так, что ногу сломишь.
--- End of inner exception stack trace ---
w3wp!library!8!02/22/2012-18:13:14:: i INFO: Exception dumped to: C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\LogFiles flags= ReferencedMemory, AllThreads, SendToWatson
w3wp!library!b!02/22/2012-18:14:19:: Call to GetSystemPermissionsAction().
w3wp!library!b!02/22/2012-18:14:22:: Call to ListChildrenAction(/, False).
w3wp!library!f!02/22/2012-18:14:24:: Call to ListChildrenAction(/BTR, False).
w3wp!library!b!02/22/2012-18:14:25:: Call to ListChildrenAction(/BTR/Pearaamat, False).
w3wp!library!8!02/22/2012-18:14:27:: Call to GetPermissionsAction(/BTR/Pearaamat/Kasumiaruanne).
w3wp!library!f!02/22/2012-18:14:27:: Call to GetPermissionsAction(/BTR/Pearaamat/Kasumiaruanne).
w3wp!library!13!02/22/2012-18:14:27:: Call to GetPermissionsAction(/BTR/Pearaamat).
w3wp!library!13!02/22/2012-18:14:27:: Call to GetPermissionsAction(/BTR/Pearaamat/Kasumiaruanne).
w3wp!library!8!02/22/2012-18:14:27:: Call to GetPropertiesAction(/BTR/Pearaamat/Kasumiaruanne, PathBased).
w3wp!library!8!02/22/2012-18:14:28:: Call to GetPermissionsAction(/BTR/Pearaamat/Käibeandmik).
w3wp!library!13!02/22/2012-18:14:28:: Call to GetPermissionsAction(/BTR/Pearaamat/Käibeandmik).
w3wp!library!13!02/22/2012-18:14:28:: Call to GetPermissionsAction(/BTR/Pearaamat).
w3wp!library!8!02/22/2012-18:14:28:: Call to GetPropertiesAction(/BTR/Pearaamat/Käibeandmik, PathBased).
w3wp!library!8!02/22/2012-18:14:48:: e ERROR: Throwing Microsoft.ReportingServices.Diagnostics.Utilities.InternalCatalogException: Произошла внутренняя ошибка на сервере отчетов. Дополнительные подробности см. в журнале ошибок., ;
Info: Microsoft.ReportingServices.Diagnostics.Utilities.InternalCatalogException: Произошла внутренняя ошибка на сервере отчетов. Дополнительные подробности см. в журнале ошибок. ---> System.Web.HttpException: The URL-encoded form data is not valid. ---> System.InvalidOperationException: Operation is not valid due to the current state of the object.
at System.Web.HttpValueCollection.ThrowIfMaxHttpCollectionKeysExceeded()
at System.Web.HttpValueCollection.FillFromEncodedBytes(Byte[] bytes, Encoding encoding)
at System.Web.HttpRequest.FillInFormCollection()
at System.Web.HttpRequest.get_Form()
at Microsoft.ReportingServices.WebServer.Global.get_RequestParameters()
at Microsoft.ReportingServices.WebServer.Global.IsViewerRequested()
at Microsoft.ReportingServices.WebServer.Global.IsViewerNeeded()
at Microsoft.ReportingServices.WebServer.Global.DispatchRequest()
at Microsoft.ReportingServices.WebServer.Global.Application_AuthenticateRequest(Object sender, EventArgs e)
Как можно еще проверить в чем же дело, ведь некоторые отчетики работают.. а некоторые нет, пытаются что то загрузить и ошибка выше. Датасорсе проставляю но он как то нереагирует на него.
