Старый 31.03.2022, 18:11   #1
25,644 / 848 (80) +++++++
daxrunbase: Modifying D365FO metadata using reflection
Источник: https://www.daxrunbase.com/2022/03/3...ng-reflection/
As part of our code upgrade to Dynamics 365 Finance and Operations we have removed some processes, for which the security roles had to be refreshed en mass. For this I have decided to go with modifying D365FO metadata using reflection to see how can we do it with the new file-based repository. First I [...]
The post Modifying D365FO metadata using reflection appeared first on DAXRunBase.
goshoom: Simple metadata query in Powershell (D365FO) Blog bot DAX Blogs 0 30.10.2020 15:11
littleax: Simple Rest API in D365FO, D365F, D365SCM Blog bot DAX Blogs 0 23.06.2020 14:12
daxrunbase: Interpreting compiler results in D365FO using PowerShell Blog bot DAX Blogs 0 31.03.2020 15:11
goshoom: Getting service operations from metadata (D365FO) Blog bot DAX Blogs 0 31.05.2019 10:11
daxrunbase: AOT property for kernel objects are readable via reflection Blog bot DAX Blogs 0 05.10.2018 19:12
Часовой пояс GMT +3, время: 06:46.
