Старый 28.08.2021, 21:39   #1
25,644 / 848 (80) +++++++
crmtipoftheday: Tip #1409: Count records for all tables in Dataverse
Источник: https://crmtipoftheday.com/1409/coun...s-in-dataverse
Want to count all records in all Dataverse tables like a boss? Say no mo.
SELECT CONCAT( 'SELECT ''', name, ''' AS TableName, COUNT_BIG(1) AS CountOfRows FROM ', name, ' UNION')FROM sys.tablesWHERE TYPE = 'U'AND SCHEMA_ID = 1
  • Copy all results (Ctrl-A), open New Query window (Ctrl-N), paste (Ctrl-V)
  • Scroll to the end, remove the last word UNION and add ORDER BY 2 DESC line
  • Execute
  • You are welcome
Note: the execution may timeout if your Dataverse is of any decent size. Use trial/error approach to figure out executable chunks – you probably know your largest tables anyway.
crmtipoftheday: Tip #1402: Why you should not use Microsoft Lists/SharePoint Lists for business-critical Power Apps Blog bot Dynamics CRM: Blogs 0 17.02.2021 15:12
crmtipoftheday: Tip #1400: Excluding inactive records from duplicate detection Blog bot Dynamics CRM: Blogs 0 03.02.2021 18:11
crmtipoftheday: Tip #1396: Multi-currency aggregates in Dataverse Blog bot Dynamics CRM: Blogs 0 28.01.2021 17:11
crmtipoftheday: Tip #1018: Automatically create Dynamics 365 records from Social Engagement Blog bot Dynamics CRM: Blogs 0 08.11.2017 18:11
Часовой пояс GMT +3, время: 18:55.
