Старый 24.11.2020, 05:13   #1
crmtipoftheday: Tip #1392: Missing entities in Power Automate
Источник: https://crmtipoftheday.com/1392/miss...power-automate
The classic “give me 5 minutes and I’ll whip a flow for you” did not start well. Users entity table was not there.
Options Choices:
  • It’s something trivial and I’m simply no longer worthy.
  • ‘u’ is not an actual ‘u’ but Russian ‘и’ typed accidentally but in a weird font.
  • It’s a UI bug
  • It’s singular not plural
  • I missed an announcement and it’s a new feature where only selected tables appear in the dropdown and I need to enable some obscure setting. “It’s for your own good” kind of flag because it’s a coveted systemusers entity @&^! table.
At this point the only thing I was happy about I was not running a screenshare. I went for a copout. “Something is not right, give me 20 I’ll call you back”.
18 minutes in, table (the physical one) dented. Take this:
Save, close, reopen. @#%*&^%!
I forgot 3 years ago the client insisted on Employees rather than Users despite my plea not to rename. Nostradamus is my middle name except that my gloomy predictions only apply to my own doomed future.
Lesson: if you can’t find a table in the connector dropdown, check if it hasn’t been renamed. As far the blame is concerned, I’ll go with Occam’s razor – sometimes I’m simply not worthy.
crmtipoftheday: Tip #1384: Inline Code in Power Automate Blog bot Dynamics CRM: Blogs 0 23.09.2020 15:11
crmtipoftheday: Tip #1372: Synchronous Power Automate Flow on create/update of a record Blog bot Dynamics CRM: Blogs 0 30.06.2020 07:17
crmtipoftheday: Tip #1363: Get Environment Variables in Power Automate (and Power Apps) Blog bot Dynamics CRM: Blogs 0 09.06.2020 23:17
crmtipoftheday: Tip #1362: Trigger Power Automate on Associate / Disassociate Blog bot Dynamics CRM: Blogs 0 08.06.2020 14:11
crmtipoftheday: Tip #1359: Whose fault is it in Power Automate? Blog bot Dynamics CRM: Blogs 0 03.06.2020 11:11
Часовой пояс GMT +3, время: 06:53.
