Старый 18.10.2019, 08:11   #1
stoneridgesoftware: How to Connect to Your Non-Production D365 Finance and Operations Database
Источник: https://stoneridgesoftware.com/how-t...ions-database/
Microsoft recently changed where Azure databases were stored for many clients which resulted in some confusion about why ‘in non-production’ users had been able to connect to their database, but now couldn’t.
Around the same time, Microsoft made a change to how you connect to the Azure databases which is outlined in this article.
To connect your Dynamics 365 Finance and Operations database follow the steps below:
**Note that you have to connect to the Azure database from one of the servers for that environment.  You cannot connect to a UAT Azure database from the Test AOS.
1) Connect to one of the AOS’ or the BI server for the environment you want to connect to Azure.
  • Go to the environment page in LCS:
  • Go to the Local Administrator accounts section and pick one of the environments and login
2) Launch SQL Server management studio
3) When SQL Server Management Studio launches it will want you to connect to the server.  Here is how you get all the values
  • For the Servername, you need to go to the database accounts section for the environment page and find the entry that has axdbadmin for the username.
  • You need to copy the SQL Server name which is the part before the \ in the SQL Server\Database name field.
  • Paste this value in the Server name field in SQL Management Studio.
  • Then you need to add .database.windows.net to the end of the string.
  • Change the authentication drop down from ‘Windows Authentication’ to SQL Server Authentication
  • For the Login field type in axdbadmin
  • For the Password field, you need to go back to LCS and for the entry with axdbadmin for the user name click the copy button before the password field to copy the password
  • Paste the copied password into the password field in SQL Server Management studio
  • Click on the Options button in the lower right-hand corner
  • That should have brought up the Connection Properties tab. You need to past in the database name in the ‘Connect to database’ dropdown.  Note clicking the dropdown and selecting browse server will result in an error.  You have to paste the database name in this field.
  • To get the database name you can go back to LCS under database accounts. Find the entry that has axdbadmin for the username and you want to copy the part after the \ in the SQL Server\Database Name field.  Also, note that you don’t want to copy the (AXDB) portion.
  • Paste this in the value copied from LCS to the ‘Connect to database’ field.
  • Click connect and you will now see your Dynamics 365 database listed
If you need assistance with this process or don’t seem to have the correct permissions, reach out to the team at Stoneridge Software for help with your system.
stoneridgesoftware: How ‘One Version’ Affects Dynamics 365 Finance and Operations Users Blog bot DAX Blogs 0 10.05.2019 19:16
stoneridgesoftware: How to Extend Sales Order Update Functionality to Custom Fields in D365 Finance and Operations Blog bot DAX Blogs 0 08.02.2019 22:11
stoneridgesoftware: Stoneridge Software’s Top Dynamics AX / D365 for Finance and Operations Blogs of 2018 Blog bot DAX Blogs 0 05.01.2019 05:49
alirazazaidi: Production / Manufacturing courses D365 For Finance operations Courses Dynamics learning portal links Blog bot DAX Blogs 0 24.08.2018 20:15
stoneridgesoftware: How to Resolve Code Merge Conflicts after Upgrading to Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 12.07.2018 11:11
Часовой пояс GMT +3, время: 17:51.
